Configure Fast Leave Mode
Configure fast (immediate) leave mode to alter the leave processing on fast leave enabled IGMPv2, IGMPv3, and IGMP snoop interfaces. Normal IGMP behavior is skipped. Fast leave mode provides one command that controls all IGMP fast leave enabled interfaces.
You must enable explicit-host-tracking before configuring fast-leave mode for IGMPv3. For more information on enabling explicit-host-tracking, see Configure Explicit Host Tracking.
If a single user connects to an interface, you do not need to track if other users exist on the interface to perform the fast leave. In cases like this, you must change the mode to one-user.
Important
Fast leave mode applies only to fast leave enabled IGMP interfaces.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must use VRF Router Configuration mode.
Change the mode to one-user.
Switch:1(config)#ip igmp immediate-leave-mode one-user
Variable definitions
Use the data in the following table to use the ip igmp immediate-leave-mode command.
Variable |
Value |
multiple-user|one-user |
multiple-user removes from the group only the IGMP member who sent the leave message. Traffic does not stop if other receivers exist on the interface port. This configuration is the default. one-user removes all group members on a fast leave enabled interface port after receiving the first leave message from a member. This behavior is the same as the conventional fast leave process. |
